look what happened to my spacers
put my mim 1900 back on last week and thought the rear needs spacing out, so got on ebay pair of 15mm £50 btw i did not receive them in this condition IMG_0213.jpg
  • Replies 9
  • Views 1.2k
Hmmmmm they certainly look good quality :lol:
seen it before.. i think its where it has a rounded edge, the wheel will squash up against it and snap it as it dont fit properly
thats what i thought, wouldn't tighten up (even with the longer bolts that came with them) i'd say its cus there cheap but £50!
what id do if you cant send them back is get the centres machined off so there flat, or just have a tiny lip
Did you clean up the rear hub before fitting?
i didn't know the rear hubs needed cleaning before using them
I've had the same thing happen. it only happens when fitted on the rear hubs, i did work out the cause, but cant remember now, think the issue is due to the spigot ring on the rear hubs are slightly different to the ones on the front, from memory the rear drums have a tapered bit before the spigot and this contacts with the spacer which doesnt have an opposing taper. as for the quality, any aluminium spacer will be made of that sort of quality aluminium, i.e machined fron cast ally. if you pulled a cast alloy wheel apart in similar fashion, it would split in much the same way.
This would make sense looking at where the spacer has broken. There will be less material around the spigot because of the counterbore for the spigot on the hubs. Basically, the hole in the back that slides over the hubs.
If there isn't a taper on the spacer but there is on the hub then when you tighten them up the metal will just crack as it's probably the weakest point.
I'd have thought they would machine a taper on the rear just in case as they are meant to be universal.
It's always good practice to take a wire brush to the hubs to remove any build up of rust or shit that may of occurred. It could be that these spacers are made to a slightly tighter tolerance on the center bore than the wheels you have been running and some shit that didn't give your wheels an issue could cause a problem with the spacers
