Rust...ways to treat it?
Got very slight rust on the offside Rear arch. I've had a good poke with my finger and it seems like its only surface rust. ill wait till i get her in the air and get the rear wheel off to have a good tap around and look under neath the arch to see if its just on underside of the lip.
if it is only surface rust and its not too bad, would it be best to sand it down, use some filler and repaint the area?
  • Views 885
Yep some 80s grit paper on a da grind the rust out , bog it , sand it down & then primer , paint & laquer it
Sweet cheers mate, hoping it aint too deep, dont fancy having to cut it out :) cheers for the advice
When you've done sanding, a bit of rust convertor on the area is always a good bet.
KURUST FTMFW! sand down, paint on kurust, prime, spray, enjoy.
