Painting with Acrylic lacquer - HELP please
Guys I need some help.
I've been learning to do the paint and bodywork on my mk2 as it needed a full respray and many body work faults fixing.
The relative who has been teaching me has not painted a car since the late 70's / early 80's.
Basically we are using acrylic lacquer but the guy in the supplies shop sold us some MIPA C10 Acrylic lacquer and told us the 1 litre can should be enough to do the car!
So we are thinning it down but I've used way more then the guy said., My relative is used to painting with cellulose, and we have had to use far more paint per panel than the suggestion by the paint supply guy, with the older style paint we would normally have done a wet on wet series of coats.
Its a bit embarrassing but so far we have used 2 litres of acrylic lacquer and only done about 65% of the paintwork of my loon. The bits we have done have polished up by hand a little and it looks like it will be a decent finish mostly (apart form where i didnt do the metal repairs well enough - or previous repairs have become more apparent).
Can people share their learning's with me - should i be thinning it down a lot more?
Is there something else I should be doing?
Am i creating a harder final polishing task as the acrylic is harder than old school paint?
Is using this much lacquer going to cause me problems?
What is the best way / process to paint with this stuff?
I'm also getting a lot of sink-age.
Experience shared appreciated.
Its starting to look like a car again - lacquer not polished
You can see the polished finish hasnt been done yet - had a quick wipe by hand near the edge with t-cut.
JC
Edited by Retrotub
  • Views 2.2k
sadly I've not had experiance with that product but i can say that 1ltr wont be enough to do the whole car, the single pack can be very difficult to flat and buff if you leave it too long
what stuff are you using? 1k acrylic? didn't think you are supposed to thin it, as its pretty thin anyway? i only really use celly based paints, but have used 1k acrylic over the top of celly on certain wheels I've refinished. i would have expected to use 3 to 4 litres of lacquer to cover a whole car, i can easilly use half a litre of lacquer on a set of wheels, lots of wastage due to the shape of wheels, but it isnt a huge surface area to cover!
i think its likley it would be ready for use as is ...and it doesnt go very far at all so no way will 1 ltr get round it
sounds like the paint shop man is a tool
sorry to say the 1k clears are poop , chances are it will yellow or crack before long
