Repairing a dented/scuffed sill
Had this happen yesterday, scraped on a curb :(
Just wondering how I can make this look okay...not perfect, just okay will do! Is it dented too much to just grind away the paint and use filler? I've seen people suggest using a slide hammer to remove the dent but a) I don't have one, and b) I don't want to go to the expense of buying one. Any other way I can possibly pull it out slightly so I don't have to use toooo much filler?
Cheers,
Cal
  • Views 1.8k
Think the only real way is a slide hammer if its the same thing as I'm thinking of.
Skim some filler over it and spray it up, shouldnt be too noticeable down there.
Could go to a breakers and find some subtle side skirts that can be bonded on..
tag some wiggley wires ont to it and put the pulling arm on, it'd come out nicely. sadly if your doing a diy job and you done have use of said tools then youll have to fill it, try building the most of it up with fiberglass filler first then a nice skim of glaze to finish it off, have fun lol
Seen a slide hammer /dent puller on eBay for like 15 quid so may try that. I assume drill a couple small holes, screw in the self tapping bit and pull out as much as I can, then wack the filler on?
Only for it to be whacked off again by the MoT examiner, if he suspects there's a hole under it.
My old man says I should be able to pull most of it out so will only need a light skim of filler to tidy it up.
