has anyone ran a g40 charger on a carbed mk2?
i wanna know this about the looms for other reasons myself as i have a plan of action for my car
same, changing the looms over is the whole reason i posted this topic, as its gonna be effort!
  • Replies 67
  • Views 2.7k
well my question is the interchangeable bit as I'm thinking of using a g40 ecu on my turbo afh for a start before megasquirt just wanna know if the ecu connections are the same and the plugs to join the injection looms to the main engine bay loom is the same
yeah I'm unsure where it all plugs in bla bla
i will just splice looms together if i need to for the various parts
what are all the sensors the g40 uses as this will help people to so they know what else it has over the standard 1.3
think it has a nock sensor? i think thats the main difference.
charger mounts not a problem as its only an extra brace for the charger, grinded mine for ease of mani removal, problem is your standard mani may be in the way of the charger being tensioned.
saf does have a standard g40 mani iirc.
nah i have a 4 branch thats the problem lol, it dont have the bend to go round the charger lol
my block has the tapped hole for the knock sensor
they also have the wide open throttle sensor
any other sensors they use over a standard 1.3
Loom has co pot, W.O.T. switch, idle switch, fuel rail, lambda, knock sensor, coil, dizzy, ecu, which also has a MAP sensor.
The engine loom and ecu are all standalone and there's very few wires you need to splice into for the fuel pumps and an ignition live circuit.
There's no other thread bar the supercharger? FAQ thread that you need to read on this subject!
Ps fucking forum filters turning w o t into what. FFs!
Edited by Cymro
sorted.
well that makes it worse then :lol:
Still doing it cheaply isnt easy, a good condition charger is going to set you back £200-300, charger/engine mount, boost pipes, intercooler, some sort of management, carb...its going to add up :/
theres always bargains going around, was a charger for £150 the other day.
ah well well see what happens! either way its all good info to have
I do actually have a spare intercooler now you mention that.
Lets not forget getting the charger to fit in a mk2 aswell :lol:
It fits, just difficult to get off I thought
bit of slam panel cutting, mint
Comeone guys more advice on charging my hk with standard ignition/dizzy
You've been given all the advice you need, its not going to work... Well it will right up until the first time it hits boost and pinks so hard your pistons shit themselves :thumbsup:
And possibly the crossmember too!
fair play, ill stop hoping now haha.
getting bike carbs for now as my pierburg just went gay
