jacks.
So I tried replacing my wheels yesterday to find my trolley jack won't fit under the car. Had to borrow a sill pincher from some local pikey to raise it enough to.get my proper jack under. Lowered car fail.
Are there any slimline jacks at a decent price?
  • Replies 23
  • Views 2k
Should just drive onto a block of wood then the jack will fit under
Haha common sense is becoming extinct
there are a fair few about, your looking around £100 though so not exactly cheap :/
Best bet is to get some wood as mentioned by matt-c
As if I've got a big bag of wood out the back too. Fml.
Got my low profile jack, £50 off the bay, does the job perfectly.
I have a super low entry one but still need the car on a block of wood due to the sill! I cant believe you didnt think of driving up a curb or anything :/
Ebay. Just search racing jacks. Lol
I use the jack out the boot to raise it abit then slide the trolley jack under
lol either drive on a piece of wood, or get a friend to rock the car (window down lift and shove motion) while you stick the jack under...
Got my low entry jack from machine mart for about 50 quid.
Everyone says to drive onto a block. Your fucked if it's broke and that's why your trying to get under it haha.
Any chance someone can scan in the bleeding instructions for one of the light weight jacks?
Mines suddenly having problems lifting the polo. :lol:
bleeding is pretty simple
let the lifting arm down to bottom ( may need some assistance to go down fully)
Keep the screw ( the one you undid to lower the jack arm) twisted out a few turns and pump the handle for a minute,
tighten the screw and bobs your uncle
if this doesn't work you may need to top up the fluid, or service the jack seals. videos on youtube
Well luckily not everyone weighs less than a ryvita so pushing a car on a brick isent the end of the world.
I could probably push it onto one... but its stopping it from going all the way over when you have momentum that id struggle with lol.
Guess ud just use a chock to stop it.
But still, effort :lol:
Edited by B-shaw
Fuck pushing a car around when you don't need to, widow makers do the job of lifting it enough to get a decent jack under
If you cant get the jack under, just scrap it! :p
I once got a flat tyre and had no wood so drove the front wheels onto the curb
it gets longer when you cant really get a stack of wood infront of the wheels, and you have to take the bumper off before you even start.
You have a lowered car, you lowered it, just hack it
