Removal of Interior
Vw POLO 6N
Does any one know how to remove the air vents that are located at the either side of the dash?
I want to replace the faciar around it please.
  • Views 2.7k
Flathead at the bottom where the vent meets the facia, gently pry open :) be careful though as quite fragile
Thanks. So the vent stays in place but the plastic facia around it comes off? or does the vent have to come off too.
They come out as a whole unit,
This is for a LHD but the method is the same
Removing
– Unclip vent housing -arrows-.
NoteDo not dismantle housing and adjustable louver further (vent and adjustable louver are one spare part).
Removing
– Remove light switch → Rep. Gr.96.
TY so much.
I also want to remove the bottom console where the gearbox is. The whole console.
Do I remove the gear nob, remove leather gear stick cover? Then from there unscrew and remove all of the housing/faciar?
I think you can get away with just unclipping the gaitor for the gearlever
Compartments, covers and trim
Removing and installing centre console > 09.99
1) Cross-head screw ◆ 1.5 Nm
2) Cover ◆ Clipped
3) Hexagon nut ◆ 2 Nm
4) Centre console
◆ Removing:
‒ Unclip cover -2- and take off upwards.
‒ Remove hexagon nuts -3-.
‒ Remove cross-head screw -1-.
‒ Lift centre console rear of threaded pins -6- and take off gearstick
◆ Installing:
‒ Place spacer sleeves -5- on threaded pins -6-.
‒ Fit centre console and secure with cross-head screws and hexagon nuts -3-.
5) Spacer sleeve
6) Threaded pin
Thats it. That should cover it all when i go to the scrap yard on Monday. Thanks!
