Rust Spot
What would be the best way to get rid of this bit of rust?
I've looked around and just wondered if there'd be a quick & easy way to get rid of it and paint over it as it's quite small?
  • Views 813
What looks to be 'quite small', may well develop into something much bigger as you rub it down.
The problem has obviously been caused by rust starting behind a door edge protector.
It depends on what sort of quality you want from the repair, for a start, red colours always fade in sunlight more than any other colour, so you would be very lucky to get a perfect match if you just painted the affected area.
Whether you decide to just paint the damaged part or the complete door is up to you, but whichever you do, you will need to rub that damaged part back to bright metal (when you look at the enlarged picture, the damage is quite deep).
If you can't get back to bright metal without the risk of making a hole in the panel, you should treat the affected area with 'Jenolite' or similar before applying several coats of high build primer.
You may even have to resort to a LITTLE body filler in order to get a good surface on which to apply your paint.
Regards.
right. thanks for that mate!
regardless of what size repair you decide to do you NEED to grind that rust back, i would have said that being where it is that your rust has started in your door seam, try cleaning the inside edge up too to ensure it stays away longer, (could also have been caused by the door being hit and chipped on a wall or something but check the iside all the same)
