Anyone done anything with this on their 6n2
Is their anything do-able to it? Looks crap with the paint all cracked, was told by a body shop they couldn't fill it In flush
  • Views 994
could you not fill it and smooth the the back (taking away that little groove)
no matter what it will always end up cracking if you try smooth over it with the vibration off the road going through the car
best solution is to weld a plate over the section under the light so the line is completely covered and it will never crack through the plate
That's what I asked but was told I couldn't because it would crack. Thanks for the advice
if they just fibreglass it then it willl crack, if they weld a plate in then your safe
Just an idea - chemical metal. you can buy the lumps you kneed in your hands and then smooth the crack with and sand back when its solid.
Could be worth a try. Cheers mate
