6n2 tdi questions
So basically I've got a new job 30 miles away from my house instead of 1/2 and want a tdi for fuel comsumption money savings :D hopefully i can swap most things from my 6n over to it so wont have to spend too much money. I was originally planning to get a Audi a4 avant but saw a sick slammed 6n2 last night and remembered that I love polos. This leads me on to slamming tdi's. How low does the sump sit compared to say the wish bones? If I lower it as much as I can untill I need a notch am I going to be ruining sumps all the time? Can I get a shallow sump for it?
  • Views 1.5k
You'll only be able to swap majority of bits over to another 6n in terms of suspension etc as 6n2 suspension is different
Personally I wouldn't want to go any lower than I already am, am down about 80-85mm and that's plenty low enough on 14's
I also wouldn't fancy shallow sump on a TDi engine either, it needs that much oil for a reason! There's a cover that goes on the bottom of the engine but it only sits just above the wishbones, will get an up to date pic of ARB height on mine tomorrow
i know when i had mine fairly low, not sure how low now but probs somewhere between 70 and 100mm down, i know i didnt need a notch done, my sump definately took the brunt of any front end scraping, and was visably bashed in by the time i sold it.
My 6n2 tdi is sitting on the drive shaft on 185/55/14 14 x 6 wheels and the sump never hits it doesn't even hit over speed bumps only the Cat does
Edited by Josh Bmx
