Mk1, 2, G40 And 6n Parts For Sale - Will be at RR Day
This is what's left of a coupe I broke, as well as a few other goodies I'm getting rid of. Will update with other bits as I move locations. All prices are exclusive of postage and postage will be combined as appropriate (for larger items over 3kg, postage is a flat £8 up to 10kg and within a medium sized box)
Mk1
Rectangular Clock Surround - Chrome trim rubbing off - £5
Mk2
HH (i believe) inlet - has the exhaust re-circ ports for heating the inlet - £5
HH pancake inlet - plastic sort so no rust - £5
HH Metal Cambelt Cover - surface rust - £10
HH - Exhaust Heatshield - £3
Bumper Mounted Indicators - x4 - £5 each
Fan - £5
Shroud - £5
Breadvan Rear Wiper Arm - £3
Coupe Rear Wiper Arm - £3
Coupe Rear Wiper Motor - £18
Blower controls and blower - no fan or matrix. This is the part that sits behind the dash - £5
3 x Black 'star' shaped steel hub caps - £2 each
Exterior door handles pair with keys and lock barrels - £10
Brand New Stainless exterior handle inserts - £10
Used Stainless exterior Handle Inserts - £5 pair (several pairs)
Interior rear view mirror - £5
Interior Rubber Grab Hnadles - Bolted to the inside of the B - pillar. Could be used as door pulls on custom door cards - £5 pair
Variety of interior door trim and furniture - £ on application
Rear seat belts and clasps - £10 for all 3
Wheel Bolts - will fit other VWs - £0.50 each
Interior Light Holder - £3
Mk2 Inner Spot lamps - £5 each (4 in total)
Coupe Rear Lights - few small cracks - £8
Mk2 Early rubber gear gaiter - £5
2 x Master Cylinder - 1 x early (with pressure switch), 1 x late (no pressure switch) - £10 each
Header Tank - £8
Cam Driven Fuel Pump - £7 (x2)
'Bonded' Front Quater Lights - Has a single seal all around - £10 pair (postage at buyers risk)
Interior Blower Pipes - £3 each
Driver Side Adjustable Mirror - No glass, plastic casing onley - £5
Single Lamp Grille - No badge - £10
Quad Lamp Grille - Chrome trim rubbing off - £10
Seat covers in this pattern. Bit grubby but shouldn't have stained. I'm stripping these covers off this weekend (26th January). Could be used to 're-trim' some worn out seats - £10 the pair
The seat bases are also available - £5 each
Mk2f
G40 Intercooler - £20
G40 Standard Cam - £20
6n
Driver Side Alloy Engine Mount - half that bolts to engine - £3 (See pictures below)
Engine Mount with Idler Pulley - Pulley needs replacing - £3 (See pictures below)
1.6 AEA Oil Pump - Gauze has a hole through it - £5
1.6 AEA Crank Pulley - Ribbed type - £5
Miscellenous
25mm 4x100 Bolt-to-Hub Wheel spacers - £50 pair (2 pairs)
CBR600 Full Airbox with filter - for 34mm choke carbs - £15
Any other questions just ask. I will be at the RR day in February and likely Ultimate Dubs in March along with GTi Springfest in April.
Pictures of some stuff. Bare in mind some has already been sold (see list above for what I do have)
Edited by mark_crox
  • 7 months later...
  • Views 2.1k
Mods please can ypu tidy this thread up please, leaving just the first
Anyone before the rr day?
Will be at a few shows this year. Anyone want owt?
Bump
Should be at UD next week
