Rclick central locking
Hi,
To anyone who has fitted this to a Polo 6n2 without central locking or knows what to do, what did you do to run the wiring from the door to the inside of the car? Did you drill a new hole or did you use the one where the cables are protected by the rubber?
How did you give the kit 12v? Did you run a cable straight from the battery? If so, what gauge of wire?
  • Views 676
Never mind, I extended the red 12v cable with a piece of wire that was thicker than the original gauge supplied with the kit.
Edited by davidelliott294
