help with wheel studs
well guys changing my wheesl form bolts to nuts and am just wondering what size studs do i need for the conversion thanks in advanced
  • Replies 26
  • Views 2.5k
and one help with this
The standard bolts are M12 x 1.5 thread if that helps?
i know that my new nuts are 12mm x 1.5mm the new studs come in sizes 40mm 50mm 60mm 80mm
which one of then should i buy
Well it depends on what you needs and the wheels you have.. and the type of studs...
What's your reason for getting them?
the wheels i have need these type for nuts so i need studs
you can get wheel bolts with taper..
The length you need is only something you can find out. Measure the bolt hole length of the wheel, measure the nut and work out if the bolt length includes the bit that screws into the hub and then add a bit and you have the length you need.
yeah i get what your saying :? but if i just knew the standerd size of the bolt for the wheels on the 6n i could work it out form there and i still think i'd rather the studs would make it so much handy to change the wheels ect and the nuts look far cooler to :-)
Can't you just take one off and measure it? We can't guess it for you..
From vagcat M12 x1.5 23.5 For steel or aloys
not near car at the moment and wont be for a while so wont be able measure it and was just wondering so i can get them orderd
See above ^^^^
40mms one so do the trick i think :?
I would of thought so allowing for 10mm into the hubs ?
but then you have to allow for the width of the nut and you don't know if the wheel hole length is the same as standard VW wheels..
the only way you can be sure is to take measurements..
well if theres 40mm and ten in to the huds there should be penty am right ? :-)
sounds good to me :thumbsup:
thanks for the help buddy :thumbsup:
Edited by doyler
Maybe, maybe not.
You have to account for the thickness of your aftermarket alloys and the length of the wheel nuts as well. The ones in the picture look like they are about 20-30mm. It's something you can't guess...
For mine I've measured I needed 60mm for one set of wheels and 70mm for the other..
Maybe, maybe not.
the nuts are 32 mm theres are the specs below of the nuts i had the wheels in my room but moved the to my friends Saturday so can't measure them at the min
http://www.ebay.co.uk/itm/160605640965?ssP...#ht_3019wt_1002
so 7mm into the hub, say 35mm for the nuts do that's 39mm and then you need to add the width of the wheel holes..
so measure the wheel holes the i will be able to noe the correct width yeas ?
the nuts cant have 35mm of internal thread can they? or the tool you use to secure them would be pushed out. you need to measure the threaded portion inside the bolts surely not the bolts overall
depends on the nut you use.. the ones that I was looking at did.. :)
Fair enough:) i was meaning the ones on the link to the ebay ones looks like the threads only go half way.
On a side note how do i get email notifications that someones has replied to a thread i have replied to? :D
