help with wheel studs
so 7mm into the hub, say 35mm for the nuts do that's 39mm and then you need to add the width of the wheel holes..
the nuts cant have 35mm of internal thread can they? or the tool you use to secure them would be pushed out. you need to measure the threaded portion inside the bolts surely not the bolts overall
depends on the nut you use.. the ones that I was looking at did.. :)
Fair enough:) i was meaning the ones on the link to the ebay ones looks like the threads only go half way.
On a side note how do i get email notifications that someones has replied to a thread i have replied to? :D
PM'ed :)
  • Replies 26
  • Views 2.5k
Go to "my controls" then from the menu on the left, select "email options" and if you have it set right, once you add a reply to a thread, you should get an email.
If you want to sign up for replies to individual threads, then when you add a dey (not fast reply) there will be a tick box for "email notification of replies" - make sure it's ticked :-)
Or you can click options in the blue box in top right and click "track topic"
HTH
Duey
Edited by Duey
