Water getting into car somehow
basically went out to car this morning and noticed my rear passenger footwell was soaked, talking puddle of water... the front passenger was dry... is their any obvious places to look for this water getting in?
car is a 3dr 6n2 any help would be appreciated .. i did yesterday go through a pretty big puddle (unavoidable) and with the weather but if their is something i can do to stop the water i wouldnt mind getting it sorted asap
  • Views 810
a slightly open window? door seal, boot seal, you checked the boot? door membrane.....
how would the boot seal be the problem, I've checked the door seals they seem fine, their all sat correctly no splits etc... one person has said pollen filter housing but surely the passenger front would be wet if that was the case :S and the passenger window doesnt open reg is gone so its been shut fully since buying.
rear passengers footwell you said, water could run down the C pillar collect in the boot flat floor arear and run under the seat/seatbase and into the footwell.
Is it front or rear footwell then?
its passenger rear, but someone said pollen filter housing could be issue as i had it removed not so long ago but i would have thought the passenger front would be wet to...
so ill check boot seals, filter housing and the gromit where i have my sub wire running through... sealant at the ready lol
the passenger rear door card?....
