Door adjustment?
When sat in the drivers seat of my mk2 if you look up above the window in the door you can see a gap to outside.
I've just replaced the door seal in the hope that it would fill the hole but it didn't.
So i'm wondering is there any way to adjust the doors placement to the car?
Had a look at the lock and the hinges but couldn't see anything obvious, is there something i'm missing?
  • Views 1.7k
is the rest of your door sitting ok? if so and its just the top of the door frame thats out then try winding your window down, put your knee on the top of the door card and pull the top of the frame in slightly, only apply a little pressure so you dont kink the frame.
as above, or if the whole doors crooked it could be worn door pins, or loose bolts?
With a VW, yes this is good advice. Though similar 'adjustment' may be required to the window channels afterwards so the window slides in them freely (don't force it if it's stiff, sort the channels or you risk shattering the glass).
But if the problem is with a Peugeot 205/309 then it's not such a good idea - i discovered the frame buckles rather easily..
