bike carbs pissing fuel out of overflows
just fit a facet and be done with it. :lol:
  • Replies 156
  • Views 8.4k
Yes a pressure reg..... Everything has been covered. Just do without for abit and get a proper reg. You could of ordered it a couple of days ago and it coudl be with you by now rather than all this.
yeah i could have ordered it a few days ago when i wasnt sure what the problem was...
think thats a good shout tbh lol
I've got a reg at home eric with the on it you can most prob have, I've been told i wont need any sort of restrictor etc with the t-peice method ...
Let me have a look at work see if i can whip you something to drop the pressure down abit :).. What size are your fuel lines again btw ?
what reg? as if its only a low pressure one the mechanical pump will probably just break it lol. fuel lines are 6mm.
trying to find somewhere around here that sells elecric fuel pumps as i cant wait for postage... gonna be a mission!
Well its a high pressure reg from what i remember ... The Dial was like 10bar or more .. fuck noes with out it beeing infront of me ..
If i get a spare minuite today i'll make a t piece which obv has fuel in and fuel out but the other part will be a screw which could regulate the pressure.. But even if i sent it out tonight, you wouldnt get it till tomorow or monday :/ ..
theres no way itd come tomorrow dude I'm not that lucky :lol:
i need something this weekend lol :)
i was thinking though, wont a regulator just strain a mechanical pump? as surely it has to pump the same amount either way being driven off the cam?
Get a scrap motorbike tank and duct tape it onto the bonnet problem solved :lol:
do you have a scan of autodata for that? :lol:
i know its pikey, but to find out if to much fuel pressure is actually the problem is there a way of restricting the flow? like a pikey regulator? can i clamp the pipe or something?
i dont want to buy a regulator/facet pump if i dont need one.
and before ben starts, I'm trying to find out the problem, I'm not driving it like it.
A t-peice with a bolt in the uper part screwed down abit ? to restrict flow >???
No my Autodata only covers cars not hybrids :lol:
but if you can rig up a gravity feed, if it does'nt leak you will prove it's a pressure problem.
yahh, i dont think i have one spare thoughhh :s ill have to look
gravity feed?
as in like, some fuel in a bottle piped up to the carbs and held above it?
gravity feed?
Yep thats gravity feed, like what the carbs were designed to handle
ah sweet! if i cant find a t piece to bugger about with ill try that :)
Go to somewhere with who deals with hydrolics, You got a lines and hoses place or something simular around your area ?
just found an old metal t piece. winning.
idont have a tap though so fark knows how I'm gonna thread a bolt into it :lol:
Is it plastic ?? just wack a over sized bolt in .. should thread itself tbf lol
''just found an old metal t piece. winning.''
''is it plastic?''
haha :)
Shut up ...... :( lmao
I skim read everything haha ..
haha!
its only thin metal, hopefully i can get a bolt to go in it somehow :lol:
Put it in a vice .. Need a airgun or drill etc and zap it in !.
not got like a local handyman around your area ??
not really dude lol
Gay.. Got a vice ?
