1994 polo g40 conversion - now breaking
For sale 1994 polo cl coupe converted to a g40
no tax or MOT as it failed the other week, i've sorted most bits out, just needs new cv joint (the MOT sheet just says it needs the cv boot but the cv clicks on full lock) and tyre on drivers side
charger was rebuilt by the previous owner approx 1500 miles ago
new clutch and 4-1 stainless steel manifold fitted in september
de-wedged throttle body
65mm pulley
Has got a chip in it but not sure what it is (will try and find out later)
250cc injectors
oil catch tank
headgasket was done in august, along with the cambelt and water pump
the engine was rebuilt 3 - 4 years ago
the drivers side drive shaft is an uprated one
rear coilovers off a golf
did have lowering springs on the front but 1 got nicked whilst it was off the road a couple of years ago so its on standard front suspension
clear front and side indicators
big chin spoiler/splitter with DRL fitted (not wired up, just need some male spade connectors)
de-badged grill
the roof, door handle inserts and rear VW badge were painted cadbury's matte purple but i sprayed them all matte black yesterday (roof needs another coat but i've run out of paint)
it has got a few bits of filler here and there just to try and get rid of some dents
the only spots of rust are on the passenger door where someone tried to break into it (and failed), they are both about the size of a 20p.
i've probably missed quite a few bits but will add anything that i remember.
if i get enough interest in it i will break
only selling because i've got a baby on the way and i want to go back to a land rover
just the 1 pic at the mo, but will take more if needed
£1250 and i'll chuck in a boost gauge, oil pressure gauge and an intercooler off a tdci mondeo and any other bits n bobs i can find
Located in Bury, Lancs
Edited by tbpolo
  • Replies 9
  • Views 847
Anybody interested in the whole car before i break it??
pics of the bay? may take the whole car but only after engine & running gear. cheers
same as above
Sorry but i've decided to break it.
Parts that are provisionally sold are :-
bottom end
inlet manifold
throttle body
plastic intake pipe
brake servo pipe
gearbox
injectors
pulleys
manifold (possibly)
engine loom and ecu (possibly)
All other parts are available.
Could a mod move this to the breaking section please?
Tom
Hi have you got the g40 seats ?
Yep, got the full interior from the g40, needs a clean and i think the drivers seat has got a rip (not huge)
can you pm me a pic pelase thanks
If you can get it mot'd and taxed of happily pay a bit more for it!
Sorry but most of the engine has already gone.
Main bits that have already gone :-
Block
Inlet manifold
Throttlebody
Plastic intake pipe
ECU and loom
Gearbox
Starter motor
Alternator
Rocker cover
Supercharger (pending payment)
Badges
Main bits that are still here :-
Injectors (250cc)
65mm pulley set with belts
TA Technix 4-2-1 manifold
complete cylinder head
Uprated driveshaft
Edited by tbpolo
