-0.5 -1.0 rear chamber
How would this rear chamber effect my tyre wear? any particular tyre pressure I should be using any particular tyre brand etc? I will be using Ronal LS 15'' 7.5j et25 probably with 195/45/15 federal or 185/45/15 nankangs. Any info welcomed thank you in advance.
Edited by a.zdriver
  • Replies 16
  • Views 1.5k
Its all about the tow that wears your tyers, i just used washers was told 2 washers on the bottom left bolt on your hub and 1 washer on the bottom right and that works :)
That amount of camber will be ok providing you toe setting is okay
This will have a greatly varying effect depending on which side of the car you're talking about, I'm gonna guess this is for the right side?
Also the size of the washers would play a massive part in this. Personally I'd be a bit more precise if I was doing this to my own car.
You could all ways get a set of shims
Thats what I will be getting still not sure if I should go for -.5 or -1.0 also considering spacers at a later stage maybe 10m spacers.
consider the fact the car has camber already.
I fitted shims (-1.5) and ended up with 3 degrees and 9 minutes per side!
How lowered are you? 195/45 on the ronals would need arch work to go low really
Nothing is lowered yet mate I'm just planning out before I buy everything at once, I will go for 185 probably just the downside of that will be Nankangs not a fan of these tyres but no other brand in this size :(
Edited by a.zdriver
175/50 hankooks?
175/50 hankooks?
I want to stay 45 in tyre height :paranoid: Just enquired about a set of 14'' 8j rear and 7j front wheels brand unknown so plans may change again LOL
Edited by a.zdriver
But 175/50 gives the same radius as 195/45
I'm gone have to wait for an answer on the 14 if not then I'm going for ronals and then I will decide about the tyre after viewing http://tyrestretch.com/ thanks a lot for the input appreciate it! Harris is you are 6n on ronal ls too if it is can u send me your build thread
good luck with a 45 profile on 14's, Only ones are 195/45.
Haha it was on them yeah :p it's a bit beyond a set of wheels now LOL
45 would go on 15'' u got me worng there. I haven't even looked at the tyres for 14'' as I have just inquired about the 14''s.
Edited by a.zdriver
if it was 15x 7 then do 165/45. or 15x8 do 185/45, Can do the 185/45 all round also.
and 14's, tyres are crap!. I'm running 155.55 and 165/55 on 7 and 8j.
15x7.5
