6n2 wet carpet in passenger footwell
The front passenger footwell is wet. I removed a load of leaves and crap from I changed the cabin filter a while ago so I don't think it's that. The door seal looks fine. I can't see any moisture on the metalwork if I lift the carpet so it's hard to pinpoint where it's coming from. It happens when the car's stationary too, i.e. if it rains overnight, carpet is wet in the morning.
Any ideas anybody?
  • Views 1.3k
Any ideas anybody?
Could be your heater matrix mate.
Yeah i would say the same (heater) seen this problem at work.
alot of my friends are into e30's and i have seen this same problem at least 6 times lol
Does your coolant level always go down?
If not do you have a sunroof?
Also worth checking the scuttle area, if this is water logged then it's probably coming through there.
