Has Anyone Ever Used This Technique?
I've got 9j rims on the back of my 6n and the arches catch the tyres over bumps on the rear. I can't lower it as much as i want to and the tyres are showing some signs of wear from rubbing so I'm wanting to have a go at flaring them myself. They have all ready been rolled prior to the 9j rims been fitted so they just need pulling. Has anyone used this method?
http://youtu.be/1BRBe9joBbA
or this rougher method ha
Edited by polovr6man
  • Replies 11
  • Views 1.6k
the rear skins are pretty thick on the 6n and if youve already had them rolled then i highly doubt this method will have any effect, also note that if you pull the arch too far then you risk pulling the centre and the top of the quarter pannel in, you can only stretch the metal so far so be carefull
I tried the Argos catalogue method, Did nothing just ruin the catalogue now I can't buy my barbie dolls.
really you need to get the top rear bumpier mount grinded out and that's the only bit that catches on mine.
Also this is how i did mine, Just USE a heat gun, i didn't.
Polow-7 by JSmithPhtog, on Flickr
Okay thanks, yeah they are double skinned rnt they. thinking about it now, i think it was just the fronts thats were rolled as the rears couldn't be done. might be wrong though. ill have a go at it tomorrow, if i can't do it ill have to have some custom rear arches welded in.
The rears are stubborn bitches! :lol:
Haha. don't fully understand about the top bumper mount mate could you elaborate please?? and is that just a scissor jack your using?
Yes with a bit of wood. Pushed out against the hub.
and stolen from Codzilla's thread.
^ ouccccch.
just use a hammer, i gave mine pure abuse (not as much as chris ahah) and they folded over fine, no ripples or anything.
or just go on facebook and find someone that rents out arch rollers.
I'm not wanting them folding over or rolling I'm wanting them flaring. Just seen someone whos welded 6n2 front arches onto the rear though and it looks mint, might just go for that option.
that picture wasn't for the arch but to show the bumper joint cut off ;)
Beg you sand it back and wack some primer on at least :)
