What gearbox oil ?
I'm looking to change the gearbox oil as there's over 130k on the car it's a 1.9TDI pd polo 9n what oil would be best for a smooth gear change cars flywheel and clutch was changed about 100k but the mechanic I think may have put the old fluid back in
  • Views 6.4k
Specification:- Gear oil G50 SAE 75W90 (synthetic oil) The gearbox oil G 052 726 A2 SAE 75W can also be used for all gearboxes.
Qty 2 litres
Does it matter what brand or will the better brand be a better oil ?
As long as it conforms to the G50 spec and is 75W/90 synthetic, the brand should'nt matter
Nigel's right - officially.
However, i disagree. Yes, with Volkswagen. Madness? Well, they fucked up - and thousands of their cars have suffered premature gearbox failure on that oil. Failures that weren't happening previously before it's use.
I use 80w/90 hypoid mineral, i've broken a few units as they came, but never after a clean up on that oil. Last one i did was longer ratios for a 6n valver, 19k in 10 months, nice slick change, seamless the whole time.
I may be wrong to blame the oil despite the pattern, there are other factors such as the car's weight/power/clutch/tyres but still i won't use 75w synth. Synth is for engines.
