Oak Green Mk2F Polo AFH on Carbs
may need to just nip the hub nut up on the rear wheel bearing slightly if theres play and they're new
  • Replies 479
  • Views 55k
  • harris.racing
    harris.racing
    Just ignore 90% of the internet lol! Nobody has issues with running temps unless something's fucked
  • harris.racing
    harris.racing
    Progress looking good mate :)
  • dart_strife
    dart_strife
    Uugghh the smoothing process, welding done, final fine filler in progress. Then the paint :-)
Cheers for the advice bro, I will check it out. I haven't done much work on the polo since I sorted the tax and MOT out. I noticed a minor oil drip from my timing end oil seal, which was new from VW, so I am now having to raise the engine to address the issue before Bogg brothers. I purchased an engine hoist off Ebay for £136 and received it the other day, can now have big boy tools since i have a garage now :-).
I had my first semi pro cage fight on Saturday in Durham, this is the reason why I haven't done much work on the car, I have been busy training and cutting weight to get to 78kg. I won the Fight to, Round one, 1 min 1 second in by triangle.
Here are some pictures of my new workshop and garage, it needs some work, but is awesome allready.
The engine is all ready to come out too
I've been busy busy, all ready for Bogg on sat morning!
Noodles fitted on choke cable and throttle cable.
Bay is looking sweet now, just need to sort out my custom scuttle pan.
Bloody jack failed again! I guess you get what you pay for, so a £60 wolf 4 ton jack , its a big boy, 435mm of height.
The last earth cable has been replaced, £5 from Euro, all four are done now.
4-2-1 manifold is sorted out too, I grinded off the air intake tube, much better.
Completely forgot to add the stage of fixing the oil seal, and timing it up correctly.
Engine out again, getting pretty good at this now ha.
So much room! love it in here, man cave!
Oil seal done again, bloody about £20 from VW, oiled it up, and cut a coke bottle up to use a sheet of thin plastic to slide it smoothly over the crank end and into its housing. I then used a large socket piece to drive it in.
Cam marks lined up
Crank sprocket lined up.
And finally the timing belt is on all correct, what a ball ache that was!
Edited by dart_strife
Finally some pics - lots of em! Lots of work!
Blimey you like paint, but it looks really well so far. Couple of strange colour choices but it's all about making it yours.
The steering wheel i'm sure is from another MK2F but i don't know year/model.
Steering wheel from MK2f M reg ish Boulevard Coupe
Bogg Brothers was a good run for you, Unlike my air leaks!!
Lol, I know. Happened to me last time . At least we know what to do to fix yours though.
I now need to rebuild the bottom end I think , the engine don't sound to healthy .
Massive work your doing hope it works out well
Yer well , it needs doing , iff I want to justify the rest of the project. Engine compression test unit came today :-)
Lol I have ordered a mechanics stethoscope to help diagnose this noise ! Didn't know such a thing existed :-)
So I did the compression test on the AFH today, and the results were:
Dry test:
Cylinder 1 = 85 psi Cylinder 2 = 75 psi Cylinder 3 = 65 psi Cylinder 4 = 70 psi
Wet test:
Cylinder 1 = 80 psi Cylinder 2 = 80 psi Cylinder 3 = 75 psi Cylinder 4 = 75 psi
So what does every one think ?
Any one know the ratios for an AFH?
Any one want to do theirs to compare for me ?
Did you do that with the throttle wide open?
you don't need the throttle wide open for it to work and like I said to you they should be reading over 160 psi
I've tested a few AFH engines and also tested 2 hybrids all of them reading minimum of 180 psi and one 220 psi with all the cylinders reading well within the tolerances of each other
the one AFH I had ring failure on was reading 45 and 55 on cylinders 1 and 4 and 140 and 145 on cylinders 2 and 3
Did mine both ways. Wide open was more like what i was expecting
Literally 100% correct. Mine were half as much as they should be with the throttles shut, like 60psi, with them wide open it was 175psi
I've never done it with throttle wide open and have always got good figures i just let it turn over a little longer if anything
Was this with an EFI set-up or carbs dude?
Iv always been taught/shown to do it at what, and also not sit cranking for ages to let it build up; it should virtually reach it's maximum value within 2-3 cranks
that was with both efi and carbs on various cars now and it only takes 4-5 cranks to get to the right pressure if they are good anyways
i know that efi will do this without W0T as it generally has a large plenum after the throttle plate but i can see the reasoning with carbs to do it
next time i do it though i will try it on W0T and see
I've never been taught how to do it i just learnt myself and the way i did it worked so i carried on
Edited by StinkyPete
No my throttle was not wide open , how ever I cranked them over untill the reading would not go higher
Actually now I remember , I did have my foot down on the pedal all the way each time. I received some info off a lad at VW, that the psi reading should be 105 new. But I don't really believe this , as Pete says different from actual readings off his engines , bottom end rebuild time :-)
I'd expect at least 150psi, should be higher still I reckon.
Do a leakage test
I corrected my reply above regarding my compression readings, I did my Wet test, which were the 2nd readings. Is that a leakage test?
While the engine is out again, as a rebuild is likely I am going to do the below jobs.
I am going to buy myself a MIG welder and grinder, while the engine is out I want to do the following jobs:
Remove slam panel, have it powder coated, and fix it in a way that it can be removed easily for removing the engine ect
Smooth bay
Remove fire panel
Battery in the boot
Weld in new jacking points
Under seal under the car and wheel arches
Add a flexi pipe connector to my exhaust manifold down pipe to center
Weld in carbon canister hole
Weld on a stainless top to the radiator
Possibly incorperate bike carbs air box
Add my vauxhall front brake upgrade and 22.2 mm master cylinder
Re-do front brake lines
powder coat rear beam
Trying to think on any thing else?
intercooler? wtf ?!??!
Bin doing some reading , and some people have fitted them to aspirated engines , to keep them cooler . But have been reading a few negative comments about pressure drop along the whole system . Need to think of ways to keep the AFH cooler , some lads have mentioned high temperature gauges , unless that's down to being a bit pikey with parts ?
