Oak Green Mk2F Polo AFH on Carbs
Dismantling them drums are a bitch ! More bits have been turning up today , really can't wait to get the polo on the road. Vw fest is looking promising this year :-)
  • Replies 479
  • Views 55k
  • harris.racing
    harris.racing
    Just ignore 90% of the internet lol! Nobody has issues with running temps unless something's fucked
  • harris.racing
    harris.racing
    Progress looking good mate :)
  • dart_strife
    dart_strife
    Uugghh the smoothing process, welding done, final fine filler in progress. Then the paint :-)
Get it at GTI fest!
More progress.
I have been cleaning up the underneath of the car for a fresh lick of under seal, time consuming and dirty work ha.
Petrol tank section
Petrol tank feed pipe section, the amount of dried dirt that was in there!
petroltankfillertankfunelindsreararchcle
Passenger side wheel arch
Drivers side wheel arch
Spare wheel section
Passenger side wheel arch under sealed
Drivers side wheel arch under sealed
Petrol tank off, going to paint it also
Edited by dart_strife
Some more bits for powder coating:
Rear suspension cups / petrol tank strap / rear beam hinges
variousbitsforpowdercoating_zps025aab8f.
Brake drums / brake drum back plates / rear window wiper / stub axles
brakedrumsb4powdercoating_zps6557c290.jp
Floor pan under car under sealed
Spare wheel section under sealed
Petrol tank section under sealed
petroltankfloorpanundersealed_zpscccfa0b
I am waiting on my top notch brake pipe flaring tool and my powder coating now, I'm going to minimize down all the petrol tank piping as I originally blanked the feeds off ect as I could not access them under the petrol tank, I will use new piping for the feed and bin off the accumulator. I may put the inline fuel pump in the boot with the bike fuel pump too.
What a pain , fitting the Vauxhall brakes today , and the mk2 golf brake pads don't fit. Ordered some Vauxhall ones off Euro, good job they have a sale on , only a tenner. Can't send them back either, had them sat around for ages .
Been at a bit today, Under sealed petrol tank, this is now on and hoses attached.
Brake lines are all on and done, even fully heat shrinked in black.
Front brake calipers are on, vauxhall astra gte ones, 256x20 mm with vented disks.
The 14 inch steel wheels are a really tight fit, when I turn the wheels I can hear a faint catching on the outside of the caliper, and the inside of the wheel, I need to test fit my Ronal alloys, maybe they will have more room, with no rubbing.
Some more progress :
Powder coated bits are back - drums / back plates / stub axles / petrol tank strap / compensators / rear wiper / rear beam brackets / rear suspension cups
Powder coated rear beam
Bushes on beam
New hand brake cable brackets on beam
rearhandbrakecablebracketonbeam_zpsbd5ce
rearhandbrakecableonbeam2_zps84555688.jp
Rear drums assembled
Shoes in the drums
Drums on rear beam
Rear suspension assembled
Rear suspension and beam on car
Rear beam brackets on car
Really am getting closer to the finish
Looking good mate, All properly done and fresh, Just basically going to be a new car haha. GET IT DONE!
A bit more done
Replacement rear number plate light covers, brand new replacements from a mk2 golf. £8 each off amazon.
My panels are back from the sprayers
Boot
Bonnet
Bumpers
Wings
This is awesome mate
I have successfully relocated the bike fuel pump, inertia switch and fuel filter to the boot, they are all behind the velcro carpet covering the passenger light.
Here is the fuel line and also cable from the battery to the starter motor, which will be hidden by the carpet, from in the boot to under the car,
Here is a pic of the fuel line under the car, and aslo the rear brake lines and flexis.
Here is another pic of the brake line and flexi.
rearbrakelinesandflexiundercar_zpsfaad3f
Here are my wings under sealed.
And here is a pic of the wings lips folded.
not gonna lie i thought you was a bit special at first, but your actually making a rather tidy job of this :lol: keep at it man
My bum bums tight , while I'm pulling the crank off haha !
Many incidents have been going on, and the car has been put back. But I have managed to get some more work done.
I stripped the rear seats to repair some stitching, and strip the metal back and spray it up because of scratches.
Metal back sorted
Stitching repaired
And again
I have managed to start on the engine rebuild
Bottom end stripped
Head off
Bits off block
Pistons out leaving crank
Pistons removed
Piston bearing caps
Worn little ends
New little ends
Big ends seated
Little ends seated
Bottom end assembled
Oil seals on
Sump on
Fly wheel on
More to come
What your calling the little ends are actually the main bearings
the little end is the bronze bushing at the top of the conrod within the piston skirt
I did think that , was looking online for torque settings and could see some diagrams , some of them looked confusing as they all looked the same , as in big ends and little ends . So yer make sense Pete. I'm nearly there now , even put my gear box back together the other day , torqued up the case bolts to 18 lbft , just need to order some red automatic gear box oil , and clean up the head internals and put in new valve seals. The cv flanges on the gear box are tricky as they are seated on big springs aswell.
Looking great!
Giving me motivation for mine! :D
Gear box is all complete now , I have ordered some red automatic oil to help the internals last longer aswell. I stripped the head today , only to realise I don't have a valve spring compressor, I now need to wait for one to arrive :-( .
Why don't you put a slim line sump on bro?!! Looks mint tho.
Cheers bro , I've been ill for two weeks with a chest infection. So progress has slowed . But to a slim sump , I thought about it , but I hated the car with it being low in hull , so I raised it again to normal height . So it wouldn't be needed :-)
Right I'm almost there :-)
Gear box has new seals and automatic oil
It is stripped of paint and sealed up
I have now completed the work on the head, the valves are cleaned up, and new valve stem seals installed
Here id the head with the cams out
Half of the valves are out, what a pain this is
Here are some valves cleaned up
Here is the head free of all valve stem seals
Here are the old seals at the top, and new seals at the bottom
The head is now on
And the cams are in
And here is a replacement water pipe with seals
A bit more progress.
Grill and bumper on
I have purchased the bike carbs air box for the rubbers, there a perfect fit and seal onto the piper cross backing plate
Arch liners in
Dropping the engine and box in .... again
A shot after it was dropped in
A shot of the box
A shot of the Clarence for the 4-2-1 manifold
A picture showing the clearance the piper cross has now the fire wall is gone
The dizzy needs adding, i dont think I have room for the strut brace with the piper as the angle is high
Close up of the carbs and the AFH
Jobs to do:
Sort the exhaust
Bleed the brakes
Rebuild the drive shafts
Fit bonnet
Any starting issues
New wheels
Smashing stuff pal!
Thanks max. Appreciate the posative comments pal
Any updates lad?
