Front bumper plastic insert
Only had my Polo 3 weeks, when yesterday a van coming the opposite way flicked something up, hitting my front bumper and cracking the drivers side plastic insert. I am pissed off about it. So, I am going to ring VW tomorrow to order the part. Is it just a case of pulling the old one out, and sliding the new one in? Or is it more tricky than this? Easy job?
Also, I don't suppose anyone knows how much they are? I will find out tomorrow just impatient.
Pic here, arrow pointing to said plastic to show what part I mean...
(Photo is before it was cracked)
Jordi.
Edited by Jordi
  • Views 1.8k
They are around a tender delivered on, vw will no doubt charge at least twice that and will most probably have to order it etc.
I had to replace both of mine when someone thought it would be a good idea to borrow them off my car without asking....
There is a screw holding it in you have to look into the slats and you will see it. Although if it's cracked then you can just rip it off and take the screw out after. Iirc it's a t25 screw.
Also for future reference the front towing eye is behind this panel, so if your ever in need of a tow you will have to take the panel off at the road side, and most probably (like me) you wont have a screw driver to hand so you will have to just break it...
HTH
HTH
I take it it's all one part? The slats aren't seperate?
Yes it should be all one part, get on your knees and take a look. You will see how it comes off :thumbsup:
Edited by Matt G40
Yeah I have. Going to get one ordered and change it.
What a dumbass place to put the towing eye!!
When form takes priority!
Yeah it is silly, I don't even notice most towing eye covers so why not just put as imply one on? Vw and they're infinite wisdom.
Ther is one reason I can think of though, and it's typical.. Most people will break the plastic grille when looking for the towing eye, meaning vw get a constant flow of costumers buying new grilles (£20-30 a hit), and let's face every model before this has Brocken down at some point and needed a tow.... It's quite clever really, but unnecessary. They could have just put the extra time into making them not break down in the first place...
