painting bumpers
I'm in the process smothing my bumpers and I'm just wondering how much paint is needed to, prime, paint and laquer the bumpers? And what kind of paint would be best, aerosol or done with a spray gun?
i can getr it in volumes of 500ml would that be enough if i was to go down the spray gun method?
  • Views 1.2k
not sure about amounts but gun all the way
rattlecan will just leave streaks
No it doesent?
RATTLE CANNED:
show off :finger:
that looks nice with the can but how many cans did you use?
I reckon half litre will do it. That's half litre paint, and laquer you could rattle can the primer.
Or if as above you have a warm clean place to spray them you can use a rattle can for the whole lot. I would se plastic primer them filler/high buil primer then sand snooty then light cots of color then the same with the laquer, rattle can probably needs more finishing detail, but eithe rwag will leave some orange peal.
One they have dried wel in the warm, fit them on the car then wet sand and polish.
I have used this method a few times in the past and the paint hasn't flaked off or faded etc.
HTH
Specialty cans are always better, but it can still be done with the cheaper stuff it just means more work afterwards, ie wet sanding and polishing.
But either watt of you put in that extra bit of prework if will make a huge difference, after all it's 90% prep, the painting is the easy part.
half a litre would easily do it, i'd personally gun it.....
That bumpers was 1 can of specific mix paint with a proper nozzle, not a shit halfords can.
Do did u only do one bumper with one can or did u manage to paint two?
I can get paint in the colour (met green pearl lc6m) on eBay for under £20 but I'm not so so ire on the whole 1k/pack or 2k/pack malarkey can anyone shed light on that?
Used about 500ml of paint on two bumpers for my 6n, mixed 50/50 with thinners IIRC.
Also Ben your lack of ability to spell WARM is annoying me haha
