Looking after diamond cut wheels
Just got some Starmags for my polo but they are looking abit dull recently. How can I get them shining again without polishing them?
  • Replies 10
  • Views 1.2k
Even if the Laquer has done that white worm looking bits in places? It's not terrible
I took POLOMAN's advice on another thread and used poor boys wheel sealant to take care of them. I did three coats on super resin polish then 3 of poor boys.
Mine are Rota RBR's and have a little bit of worming :( but other than that they get shiny as fuck when polished up
ITS POLOMON! NOT POLOMAN!
Edited by erixtar1992
:lol: You remembered, cheers Eric ispolishnotfrench
its actually quite annoying sometimes lol, been called ericstar a few times, REALLY??
fuck knows copied it off someone one day as they called themselves telstar for a dj name lol
i just thought it sounded kinda cool, and eric is always taken. bearing in mind i was like 12 back then and thought total_joka would be a cool email address. now i sound like a dick saying that over the phone :lol:
If cutting through the laquer does work, then you can always use paint remover to take all the laquer off and repolish them, it can take a few hours each wheel, but you can get them like a mirror with the right technique, then re laquer them. I did this a while ago on some bbs wheel and they looked like chrome.
But 9/10 times polishing the laquer will cure the dullness
I tried abit of super resin polish but made no difference
sadly unless your paying thousands for wheels these days the clear coat is of poor quality and will lift and go dull, if theve started to go milky then no amount of polishing will bring them up as its under the clear coat, if you strip the clear then you have to be very carefull as just the slightest bit of grime,water,grease ect on the surface will just make your fresh clear lift, not to mention it will highlight and show like a bitch, if your planning on striping them to re clear the might i suggest going to see a wheel specialist for tips, they will be able to help you far more than 9/10 forum gowers will. a polished finish is very hard to acheve and usualy comes from a wheel being spun upand cleared, which I'm sure you wont be able to do in your shed
That's what I said. If polishing/cutting the existing laquer doesn't work (as mostly the damage is under the clear coat) you will have to remove the laquer. Once it's removed you can then clean up the metal, it's up to you how far you go with polishing the actuall metal but for something that will give an almost mirror finish your looking at at least 10 hours per wheel. Then once your happy with the result get them painted with a good quality laquer but make sure that the wheels are warm and it's done in a warm room/booth as if they are cold the laquer is less likely to bond and will run all over the place, then once the clear has cured you will most probably want to wet sand sand it and polish, this will make the outside layer smooth and shiny. The clear is simply put over the metal to protect it and as such the metal underneath should be shiny and not so much the laquer.
HTH
