Armour door plates dont fit!?
Tryed to fit my armour door plates today. Took alot of effort refurbing and spraying them, so they look great. However they dont fit, or even go anywhere near! I dont understand this, because they came off a MK3 polo, i know, as i took them off myself, yet they wont fit mine :?
Problem is, where the screw for the handle needs to go through, the hole on the plate doesnt line up, its miles off. So it could only be 2 things, they are the wrong plates, and the previous owner bodged something on his car, or my door is different, which i highly doubt. Anyone else fitted these and could get me a pic of theirs off the car so i can see if they're the same?
Cheers, Dan.
Sure the bolt hole on the previous doors wasn't drilled out to make to plates fit? I believe this bolt hole not lining up is common when using Golf armour plates on the Polo and the solution is simply to elongate the hole, treating the metal afterwards.
Are these the plates that go around the handles?
I seem to remember reading something about the being handed, have you tried them on the opposite sides?
I've fitted a few of these armoured door guard things and they are a right pain. There are two ways i've gone about this before.
When i bought a new pair once i had the same problem and the hole just didn't line up. I bent the screw holed part of the plate out and used a dremel to lengthen the hole by 10mm or so. Applied a little pressure when getting them to line up and hey presto on they went. I beleive these were the golf type gsf tells you are for a polo but obviously aren't.
Second time round i removed a set because i wanted a clean look only to find one door had been screwed. They didn't want to line up after they'd come off either... I knew they'd come off so must go back on! I apllied a sh*t load of pressure (so much i was scared the door was going to bend :( ) and the magic hole lined up but had to get my mate to stick the screws in. These were definatley for a polo.
After comparing, the ones from gsf are different and don't fit quite as well as some of the metal armour plate slightly over hangs the door but will go on. The standard polo ones just seem to be a super tight fit but then if they weren't it wouldn't be hard to get behind them or bend them out for Mr. Car theif.
Hope this helps.
