mk3 gt or g40 wiring loom
I need a working engine and ecu loom for a gt or g40 basically all wiring from under the bonnet, I think mine is slightly damaged!? If u could post or are in the north west drop me a pm cheers
  • Views 415
Alright fella, mine is a gt loom but presumed g40 ones are the same???? Well to cut a long story short my conversion is all in and done runs fine all works it just doesn't like starting when hot unless u unplug blue temp sensor! I've replaced everything bar the loom now so I'm gunna try this next u see! So could do with a working one to see if that's the fault
They are not the same ;)
What's the difference bud? And is an nz the same loom or different again?
G40 loom has a different throttle body set up runs a knock sensor etc etc and wont run from a gt ecu , NZ loom is different as well , I've seen your thread what blue temp switch are you using I.E is it a genuine VW one ?
Nice one pal, err well the guy who ordered it and put it in said it was genuine vw but lookin at it it looks kinda cheapo might order one on my way home
