So I've wired sidelights into my indicators....
Earlier wires sidelights into the back of my indicators on my mk3.
Drilled the back, extended wires etc but when I turned them on without ignition on they are how I wanted, just them on.
Then ignition on and it appears the main bulb also acts as a sidelight? Which is not what I wanted.
Hope this makes sense, how can I have it so when just sidelights are on just the sidelights come on in the indicators?
Late Mk3? That'll be the dim dip.
Its supposed to do that. :lol:
unplug this:
and it wont happen.
I broke down once and while pissing about at the side of the road some lad came over that knew the mate I was with. He then proceeded to tell me how much he knew about vw's and how it was probably that ^ which was causing the car not to run
I'm using the system to run my DRL converted grill lamps. :lol:
wired exactly as its supposed to be for the MOT so once the dip comes on the DRL's goes off.
Ah easily sorted then. So what is the dim dip thing?
It's a resistor that gives power to the dipped beam when the sidelights are on, but at half power. I'm not too sure what the point of it was buy most 90's vws have them. Just unplug it. That way you will only have the sidelights in the indys. I've found that the dipped beam bulbs are happier and last long without this plugged in as most quality bulbs dont like being on at half power an burn out quicker.
Also this interferes with gods and relayed setups as they turn in with side lights.
HTH
