6n wing mirrors
just wondering will electric mirrors from a 6n fit onto a 6n2... will the connections etc be the same?
thanks scott
  • Views 813
The mirrors will fit, but the connectors are totally different in size and pin layout
As above they will fit, but you have to swap the pins around. I have them on my 6n2 as I don't like the stubbys. If you have both mirrors then you can get the wire colours easily iirc the where two different colours on the 6n bit I just took a chance and the way I try them first worked
HTH
