Help buying a 9n
Just need some advice
I'm trying to find a polo 9n to buy, I found one close to me and want to know if to a good deal
2003 grey 1.2 e 55hp model 3 door
72000 miles
Full mot
1 month tax
3 stamped services and the rest have invoice services
Good tyres
Small dent and scratches on some arches
No Cambelt done
£2000
What do you guys think?
Edited by alex5-polo
  • Replies 10
Milleage?
Sorry 72000 miles
Nice wee car, i bought a black 9n about 2 months ago they look tidy when done up!
One thing i would say and my mechanic has said a lot about the 9n (as mines currently in the garage) is there are a lot of problem with the engine. As it's only a 3 cylinder it's generally not very powerful but and one of those cylinders dos have s tendency to go, which is a common problem with these engines! Need new valves and piston heads any everything unfortunately!
Personally i'd say go for it but not the 1.2, try and find a 1.4 or if not go for a 6n
I have read the same thing about the 1.2 which scare me big time. Hard to find another decent one near me
My mum bought one with 20k on the end of last year for £1000 but I think that was a good deal lol.
Seems ok for her, cambelt shouldn't have been done as they don't have a cambelt haha
The number of cylinders doesn't really dictate the power, but 55bhp is not a lot in a car upwards of a ton in weight.
The petrol models do tend to suffer with timing chain issues, cooking or smahing valves. IIRC this is due to the chain skipping a tooth and contacting the valves.
Personally I'd avoid the petrols, although later models had a revision that sorted this problem. Apparently it comes from a lack of oil in the timing chain tensioner on start up. Revving them as you fire up the engine causes the chain to skip the teeth. I can only assume the sorted the pressure issues.
Go for a TDi would be my advice. Better mpg and performance. A little more pricey, but a better car
Nvm found a black 1.4 sport model with extras inc air con and rremote locking and alloys. Fsh 107k miles and Cambelt done at 95k for only £200 more .the miles put me off bu FSH equals it out I guess
Wouldn't worry about milleage, if its been well looked after (having FSH I'd imagine it has been) it'll be fine. If keep giving it a service yearly it'll go on and on. I would most definately say go for the 1.4 over the 1.2, more reliable, quicker and I'd imagine it would be just as good on fuel.
Edited by Tom86cCoupe
Good find! And a much better choice in the long run!.. Mines only 54k miles (9n) and it's already had problems so i'd stay away personally!
Really wouldn't be worried about mileage, mine has 107k, the wife's 106k and are both running fine. My brother in law has a Fabia (same 1.4 TDI engine as the 9n) with 180k and it is running fine.
