6N 1.6 Atlantic Blue
So time for another new car, build thread for this one should be appropriate as its tidy and a keeper (i think)!
quick car history in pics and in order to explain the title
1.0 L
1.6 CL
1.9 SDI
1.3 Carb
1.8 16v 318 Compact
also had a mk1 caddy, a yellow CC mk3 Golf GTI, a strom grey 1.4 6n and a blue 1.6 GLX all of which are now dead
which brings us to up to date
Take one quite clean standard mk4 flash red 1.0, clean it extensively, fit valver wheels and rear lights, a chopped down A4 aerial, rear wiper blank, tailgate debadge, coilovers and a 5 door rear pass handle and you end up with this:
I know the pics are rubbish but nm
Anyway, i picked up some BBS RD218 15x6.5, new caps, new 165 45 tires, new white powder-coat and trial fit:
then remove because its all wrong, the arches need work, notch is required and things need cutting off from underneath. style_emoticons/#EMO_DIR#/smile.gif
things on order are:
nut conversion with red anodized nuts
spacers
polybushes wishbones
piping for a notch
valver bumpers are being smoothed and painted
also have plans for the interior.....
thats it for now style_emoticons/#EMO_DIR#/thumbsup.gif
Edited by mintwiththehole1
  • Replies 71
  • Views 10.6k
  • mintwiththehole1
    mintwiththehole1
    Few things to update since last time: All the brakes have been changed now and bedded in, can recommend the brembo pads as a slight upgrade over the usual cheap stuff. Wheel fitting setup has chan
  • mintwiththehole1
    mintwiththehole1
    so, nut conversion came yesterday along with the centre caps, i had a fiddle with the arches and spacers etc, i think it needs another 5mm out on the front, may order some 15mm spacers, rear isn't
  • mintwiththehole1
    mintwiththehole1
    Well as you can see by the title this is the new polo. It's a 1.6 cl, none A/C, none sunroof, 86k miles, one owner from new minter... The colour, Atlantic blue pearl, is lovely and quite rare on 6n
Just goes to show if done right simple works sooo well :-) Get the stance right and the rest will follow
Get the pic you sent me up
na I've got it sitting better now and a touch lower, soon though.......
i think it needs another 5mm out on the front, may order some 15mm spacers, rear isn't to bad
looks a bit nose high here but isnt on flat ground
wheels and nuts :)
last time living on the drive cant get on or off without lots of wood and three people
and may have got away without a notch for some reason..... but bumpstops need cutting down more or removing yet
You did get a red 6n in the end then? ;) (I was going to swap my polo for your golf... I think)
Looks good man, simple but works well
Ha, were you? I cant remember, it was about 4 cars ago lol
yep nice n simple, paint needs sorting on the rear arches now but it is a very clean car
and the BBS were a steal and fairly rare in this country i think :)
I love this pic. Simple works sooooo well
I love this pic
Keep them coming :)
not much to update, just keeping it clean, which with white wheels is hard to do :)
however tow-eye has been removed, bumpers are on their way to being done, and an airfreshner installed... :retard:
and I'm also after some 15mm hubcentrics, some height adjust seat bases and a 6n2 gti splitter if you can help me out!
This car has made me love 8V front bumpers even more, shame your changing, I'd smooth the 8V, loooks awsome tho mate fairplay:)
Cheers mods for moving this :thumb:
N yeah I'm not to sure myself yet but I have both options we shall see.....
Man that things sat sweet! What specs out back? 8-)
Cheers dude not totally happy with it yet, atm its at 165 45s on a 6.5j et 38 with a 25mm spacer
However its suffering from the usual shoddy polo rear beam welding, so drivers side pokes more by around 3mm, and the front isn't low enough.....
small updates
did some interior fettling
take a pair of these
and these
remove these
and combine to get height adjust L spec seats
not finished with those yet, plans....
got a sump being plated as mine is all bent, fixed my splitter and changed the clutch friday, no pics of either as it was raining
However deep cleaned it over yesterday and today and took some proper pics!
Sooooo
15mm spacers ordered for the fronts
longer studs for the rear as I didnt feel safe only having four turns on the nuts :@
also developed a clicking relay since the clutch has been out, however car still runs and everything works.....needs some investiagtion
Looks Lovely..
Clean..
(Keep it 8v)
ta
:D everyone is saying i should but we shall see....
No updates as of yet, got another sump for plating
few pics taken at BVF, not by me - courtesy of Majestic Art :)
any more, throw them up :thumbsup:
This is perfect i agree with above statement stick to 8v, 16v bumpers may ruin this
Love this, wheels are so sick
Cheers people
Haha bumpers are, being painted today so we shall soon see :)
New reg plates coming to get rid of the crappy blue GB bit
15mm spacers on, doesn't make much difference, 20mm maybe but these will do for now
front and side repeaters tinted to 16v darkness...??
so valver bumpers are on still need a flat and polish though:
put the vents in not oe so a terrible fit but dont look to bad with a bit of silicone round them
all fitted up :)
i love penis
but i love this more
although that was a compliment, get out elliot!
