6N 1.6 Atlantic Blue
Notch is done, thanks to Shelvy at Dubshire, car now drives like a standard one again....
Also the wheels have finished being resprayed, ill order some new caps asap, tyres should be fitted this week sometime, then its on to fitting them
Edited by mintwiththehole1
  • Replies 71
  • Views 10.7k
  • mintwiththehole1
    mintwiththehole1
    Few things to update since last time: All the brakes have been changed now and bedded in, can recommend the brembo pads as a slight upgrade over the usual cheap stuff. Wheel fitting setup has chan
  • mintwiththehole1
    mintwiththehole1
    so, nut conversion came yesterday along with the centre caps, i had a fiddle with the arches and spacers etc, i think it needs another 5mm out on the front, may order some 15mm spacers, rear isn't
  • mintwiththehole1
    mintwiththehole1
    Well as you can see by the title this is the new polo. It's a 1.6 cl, none A/C, none sunroof, 86k miles, one owner from new minter... The colour, Atlantic blue pearl, is lovely and quite rare on 6n
He is good. His notches are super clean.
Super clean, I'm still gonna spray it over in Atlantic blue though, just to keep it oe-ish lol
Wheels are on, new caps need buying though and the arch/spacer combo needs addressing, along with obv more lows.
This box contains new brakes all rou d including drums and brembo front pads,, should be a bit better than standard
looking very good! same recaros as mine very comfortable and a great upgrade!
Ta, I think they are the best seats vw had, after CSs maybe....
Front brakes and wash in the rain today, rears tomorrow as I have no bearing grease.
Lurking in the rubbish weather: PhotoGrid_1391272814802.jpg
So perfect.
Wheel fitting setup has changed again, now using 15mm spacers on the front and 20s on the back, also used a 1mm washer behind the stub axle to try and correct the toe, however I think a 2mm washer on the botom bolt and a 1mm washer on the top bolt will fully sort it....
A new set of wheels has been aquired, just need a refurb n theyll be on. I'm also playing aboit with some nut caps I've got for the bbs, unsure on colour yet though.
Had a full wheels off wash today, much better under those arches now!
Terrible quality ^^ !!!!!!
And I still need to sort the rear arches and go down a bit all round
Still looks good, you going to any shows with this?
Yes matey as many as I can...
Looks lovely buddy. The seats look amazing too!
Rear debadged and dewipered, usual 6n smoothness is getting there: DSC_0060.jpg
WHERE CAN I GET ONE OF THEM DE WIPER COVERS FROM?
Cheers Higgo
That wiper blank is a votex one I think, however they arent hard to make out of the original piece of plastic...
Will hopefully see this at Spring fest then.
Yep probably dude
For those that may not have seen it at UD, it now has clear indis and 6n2 rears, courtesy of Big Rob, I'm still not to sure, but obv have the option to go back.
They may work better once the bbs are silver and have some 16v/gti discs hiding behind them on all four corners, in red of course. I've already made a start on these and have the main bits, still need:
Splash guards
Bearings
Rear discs and pads
Hoses
And handbrakes cables
Over a hundred quids worth of stuff, trade, plus powdercoating them red!
I poly bushed the front before UD aswell seeing as the bushes were falling out anyway...
Glad those lights came in handy for you buddy. Look much better on this than on mine.
Yep thanks very much dude :thumbsup:
Not goingto make gti fest, deffo doing big bang...
Very happy with this after this weekend, being thrashed up and down the country.
Gonna treat her to a service next I reckon.
Love this
Well due to the bloody rain it took me 2 days service and deep clean this at weekend. But its now had everthing, oil air fuel pollen plugs leads dizzy. Next is coolant and temp sensor as I think its stopping it from starting when cold...
Found that the fuel filter was most likely the 14 year old original: DSC_0238.jpg
Also resealed my headlights and cleaned up the front panel a bit today, much better: DSC_023_edit_1401127228331.jpg
  • 4 months later...
Wow, long time not updating this!
Few little pieces done like the false floor, new fitted matts, and some A1 ally pedals. Pedals look nice even though you can't really see them in a 6n, and required some fettling to get on....
But the biggest update is the bbs are back, with brand new nankangs and genuine centre caps, and a fresh coat of porsche silver.
I've also cut the rear arches, and raised the engine a slight amount so it can go down a whole load when I've sorted my driveway out....aim is to tuck the rim all round....
