arch rolling but keeping plastic trims (and rolling them too)
was wondering can this be done? I'm not on about attatching the trims, as obvs you could just bond them,
I'm on about rolling the arches, but also rolling the trims. is this possible? like heat them up or something to bend them round?
bloody things
  • Views 1.3k
Roll arch cut trim?
dont want to ruin them
roll the arch then warm the trims as you offer them over the new arch, only thing you may find is as you heat them and they stretch you may loose the plastic stippled texture
Cheers. I'm not too fussed about the texture on the rolled part as it wont be visible. I dont want to cut them away as i dont want to bodge it and it look shit, so any alternatives welcome!
What you can do is use arch trims that are bigger, maybe for a MK2/3 Golf, B3 Passat or MK2 Scirocco, then when you bend the two ends of the C shape the inner curve bends out proud of the outer curve.
Cold, the Polo trims can't be stretched. But heated? I don't know, if i had a spare i'd consider doing the following:
Heat one up by rolling most of the C in boiling water, then very slowly and carefully try and stretch the ends apart an inch. If it's possible to stretch them like this, focusing on pulling only the inner part of the C (so to suit a slightly bigger arch) then when they've cooled and you fit them to the polo, they should bend out on the inside like a rolled arch.
My career is in plastics and has been since the 90's, however i've never worked with ABS or polycarbonate and there are many different plastics with all manner of properties and cultures, so i should stress i've never done this and can't say if it'd be a success. All i know about either is they don't shrink when softened by heat like some plastics, which makes me think it's worth trying. I'd suggest trying plastic trim from a breakers but ensure it's the same stuff - i don't knowif they're ABS, polycarbonate, Polypropylene or what. I think they're too flexible for ABS but whatever it should say on the inside of the arch.
Great reply that mikey! Cheers! I have a couple spare trims i can try out
I'm gonna use the standard plastic arches as i wamt to keep the shell/body looking factoryish, the whole reasom I'm doing it is not to widen the arches, but to get rid of the arch gap without wearing through sidewalls, I'm only down 70 and my passenger rear tyre is a right state! If it gets any worse I'm gonna have to change it!
Thanks again dude!
Will be interesting to see any results, just haven't thought of it myself.
Can't think of any on a car right now, but don't try it on any form of expanded plastic - or it'll shrink!
