Mk1 Golf Small block Turbo
just like thst GREEN!!!!!!!!!!!!!!!!!!!! not so low rocco sat in the corner. the not in use at all times unit!
  • Replies 110
  • Views 16.7k
Cheap boost ftw!!!
Go for it eric!
So basically, if i fitted a turbo vaccum pot to my accuspark fitted dizzy, all id then need would be a renault 5 carb and a charger? (And obvs all piping ect)
It was the dizzy part i was confused about before!
Yes, but thinking about it, I'm not sure what vac can will fit the early dizzy :? If they're the same as the hydro engine dizzy's vac can then there's no problem 8-)
Can't even think what the early dizzy's look like, anyone got a pic for comparison?
Practically the same. It had a suppressor on the outside thought
isnt that rocco on a VW Heritage advert in PVW? :p
realllllly enjoyed that thread :)
I think i'll just be adpating the hyrdo dizzy to fit to be honest, shouldn't be hard.
I've looked at them side by side to see if this was possible before, and it's possible to machine the late dizzy down to the right diameter for the early head, but the actual rotating shaft sticks out much further from the mounting face. So the options are to either space the dizzy out from the head (meaning machining it down was a waste of time anyway), or finding a way of shortening the part of the shaft which protrudes out of the dizzy.
Hope that makes some sort of sense :lol: You'll probably need to look yourself to know what I mean.
Edit; sorry for spamming your thread Winst :oops:
Edited by Phataz1
Kind of get you dude, but like you say, gonna have to look!
Green, primer and black... Its country spec on the jig. We need more signs haha
The vac can does fit the early dizzy. as I fitted an early standard can to my hydro dizzy to sell it :)
It was indeed. It had a feature lined up but I took it to bits :oops::lol:
The spamming is knowledge. knowledge is king! so do not worry about it! :D
I would have loved to find this thread when I was building my engine 8-)
Edited by Winston
So yours is the HH right winston?
Is it running a standard CR?
I always thought it was a HH but I never checked. after looking I found out its a GK. which worried me a alittle until Arun informed me they are pretty much the same.. FEW!! :lol:
They have a low compression ratio, similar figures to the PY.
I thought the GK was a high compression engine?!?!
Its the Mk2 version of the 3F engine.
Isnt gk the 75bhp lump?
The GK is higher comp I'm sure. But you'll have the best stock cam for FI and inlet for its bigger diameter
It's a GF out of a mk1 golf lads. Same as an HH.
Problem solved! 8-)
Edited by Phataz1
I was just coming to check hoping id not put GK. didn't take long to get pulled on it haha
I always thought the HH/GF and GK cam are the same? might be wrong!
I wouldn't mind trying a HK cam to see if it brought the T25 on boost alittle quicker
Correct lad :-D If you decide not to use the Saab dizzy I have an accuspark one here waiting for you ;)
Aww yeah!!!(just for the 3 bolt fitting lol) Forgot your runing fancy injection for a minute :oops:
Edited by Winston
All three of those cams are the same? That makes me a little more postitive that I have indeed been sold the correct cam.
Winston, are you using a t25 turbo then? If so, I'm not suprised you had lag issues using the standard 1.3
Its a T2/25 hybrid but it has the same A/R's as a T25. Its no more laggy than when I had a T25 fitted to a 5 turbo. It comes on boost hard at about 3.5k and then the clutch slipped haha
Small clutch though as you said. Thats quite late on the boost. Or is it? I'm used to a diesel these days :? I hope I can find a way to bring it on a little earlier, mine will be a 1.4, so same as R5GTT
Edited by prankstar2003
The mini boys with the 1275's/1293's/1303/'s/1380's run similar spec turbos to this tbh, T3 on my old metro was awful, didnt spool then when it did i had to change gear anyway! start all over.
Hmm, might go do abit more research on the mini forums then, some of the engine specs arent ''too'' advertureous so could find a decent turbo.
The MG turbos run a tiny T3 with low A/R's similar sized to a T25. A GT17's from a saab is ment to be good.
