What are the chances...
15's make a MK3 tram line really bad anyway.
I don't see why the would be any worse than any other size? providing you are using the right size tyres to keep the rolling radius the same and you stick to a similar width tyre, I don't see any reason for them to tramline worse than any other size. It is the tyre width that has the biggest effect on a wheel tramlining, although wheel offsets can come into play.
i'd put any money that my 14s with 195/45s will tramline way more than a set of 15s running 165/50 tyres
In one breathe you say dont fit 165's then the next you say do? If thats a suggestion to the lat to run 165/50's that is.
I'd run 165's on them. fuck it, if you want handling/power you dont buy a polo! so you may aswell do your bit at ruining it :-)
  • Replies 31
  • Views 2.5k
This is the most pointless thread ever lmao
no, I said if you don't want tramlining, don't fit wide tyres, it has got fuck all to do with the original question, it was more of a case of correcting dan on his idea that 15s cause tramlining, which they don't
This.... and yet my half decent build thread gets deleted. :lol:
my original build thread was deleted because i didnt update it fast enough- certainly wont do another on here because of that now. I'm going to start a build from scratch on polo3 to show my anger at it
:lol:
back to topic, you will need to drop it loads to look good aswell, a lot of work considering it will be hard to get them on and under the arches.
