Can't remove rear number plate screws
I've had my Bora about a week and one of the things I wanted to sort first was the number plates. The front one has cracked and the letters on the rear are badly faded.
I've bought some new ones and a fitting kit (with sticky pads) but I can't get the rear number plate off. Using the right size screw driver, I can't get them to budge. All I'm doing is completely wrecking the top of the screws.
The front screws come out easily so I assume the rears have rusted in to place?
I have tried to use some mole grips but that didn't seem to help me at all. They just couldn't get enough on the screw.
Any other suggestions?
  • Replies 9
  • Views 1.8k
probs have to drill them out bro
Sounds like it could be interesting mate! What size bit would you use?
id probably start off with a very small size, maybe half of the size of the screw, to drill the middle out, and then use a bigger drill on the same hole. as it will be easier than just boshing a big drill bit straight in :lol:
Sounds like a plan to me mate. I'll have to crack on and give that a go on Saturday I reckon!
I found another thing online that used a cutter to cut down the middle of the head of the screw, so you could use a BIG flat headed screw driver to put some torque on it using a wrench and it would come out. Might be another idea worth a go.
They often snap off as they corrode into the threaded inserts
Could always snap the number plate off so you can get more of the mile grips on the screw, if the screws are to far gone be prepared for them to shear off.
yeah try what luke said, works for me everytime :)
screws are gay anyway! Cause them pain!
lol, they are!!! I'll be sticky padding the new plates on definitely, just think it looks much more clean and tidy than screws, even with those stupid black/yellow/white plastic covers.
Who ever put the original plate on put it off centre and pissed, so with that and the faded letters it looks horrible.
The new plan then; snap the old plate off and bully the screws until they do the decent thing and let me win!! :)
