Caddy 9k Dash in a 6n
Does the Caddy 9k (6n one) straight fit into the 6n Polo??
Or is it a different size?
  • Views 1.5k
Same shit, diff toilet......
I presume..
No two shits are the same... :lol:
And i presume isn't good enough!
Edited by Jonnyboi
Same as mk2 ibiza dash??
If it looks the same, probably is.....
Most VAG Parts are the same shit..
Hook a brother up with that flock................
Pretty Please
No, most VAG parts look the same, but most are different. It's actually amazing how they've insisted on changing absolutely everything all the time, almost to ensure you can't fit one thing to another.
Take the 256 brakes fitted to 6n valvers and MK3 Golf automatics. Both 4-stud. The same, surely? No, the wheel bearings are fractionally bigger on the Golf. Why! Wouldn't it have been more cost effective to use the same shit?
It's always the same with VAG. Like the '90s audi A4 where there was a change to crystal headlights - can't fit them to older models without taking an angle grinder to a hidden part of the visually identical wings..
Not even all MK2 Polo coupe rear arch trims are the same. The holes in the bonnet are a different shape from one year to another. They change shit you wouldn't think of - the MK4 Golf had a monumental revision in '03 and still today nobody has noticed.
With VAG it isn't simple. Never has been. So it's best not to be presumtious, especially when advising someone else.
I very much doubt the dash in question is a straight fit, much as it looks identical.
Ok, I'll just get mine flocked then,
As the guy across the road from me has just had his caddy written off and his was flocked. He's also the one who does it anyway, :lol:
as far as i remember they are all the same if the clocks are the same. early 6n dash do not fit in later ones (well they will fit but the clocks will not and cannot be wired to work. but early dash are same as ibiza and the caddy.
