help needed 9n3 gti sideskirts
Just bought a pair of these from vw, they have all the retaining clips and strips etc, but is there a fitting guide anywhere as i have no idea how they go together
thanks
chris
  • Replies 8
  • Views 2.6k
Stick your head under the car, under layers of underseal you will just about make out two oval grommets, pry them out and that will leave two holes per side.
Get the blocks from the kit, clip them in (cant remember which way round) and press the block in to hold them in place. Then screw the skirts to those.
Another was is screw the blocks to the skirts and line it up that way.
The front and back are merely screwed into the arches using current screws on the mudguards etc.
Hth
ok, that helps, i had no clue what the blocks were for, i also got two long black plastic strips, the same length as the skirts, these have double sided tape on, any idea what they are for?
Yip they stick the top edge of the skirt to the paintwork
but the skirt itself has double sided tape on to do that, these are seperate, do they attach to the skirt before you stick it to the car?
sorry if i sound dumb I've just never done this before
Hmmm, not sure, I got mine off a friend, all I did was a long strip down the top edge and a few pieces at the rear end
ahh well, i'll probably not use them then if i dont really need them. did yours stay on ok with just the double sided tape or did you put anything else on?
thanks for the help by the way.
The blocks secure them to the car, the tape just holds them flush to the bodywork. Be sure to clean the surface your sticking it to well
will do, thanks again
