Viewing an 86 saloon tomorrow
Just a couple of noob questions:
Are all the parts (Trim/engine/suspension) wise basically the same as the coupes of that age? I'm guessing they are?
Anything that is quite problematic to find for them?
Its in quite good nick apparently with only 2 previous owners. So hopefully I should be bringing her home if all goes well.
Edited by jordansimpson93
  • Views 852
back to the b pillar yes iirc behind that its a bit different so seats fuel tank exhuast etc will be different
ok thankyou
Exhaust is slightly longer on the middle section.
rear seats don't fold down as there's a solid panel behind them.
Suffer same sort of old car/common issues as most other polo's of that model.
check the battery tray and filler neck where it meets the tank.
Exhaust is the same up to the back box, and is only then extended. Fuel tank, rear axle, entire floor is the same - even the boot floor is the same, it just has an extension panel. Rear side glass is coupe, pretty much the only unique parts are panelwork, rear screen and rear lights.
Rear seats are different though as they don't fold, they're lighter - the frame/panelwork for them is in the bodyshell which is therefore stiffer than the hatchbacks.
Rust to worry about is then the same - rear chassis legs and rear box sections, especially around the axle mounts, outer seatbelt mounts, and the inner wing panelwork surrounding the petrol filler pipe. This is all critical stuff - on reflection things like battery tray and petrol tank are relatively easy fixes.
Make sure both front lower suspension arms are dead straight and the camber is even both sides - you don't want a bent suspension mount from a kerb impact.
thanks for the advice :)
went to see and bought the car,
87k I'm the third owner, f.s.h, no advisories on mot which is due march, tax due november.
Got a good deal I think!
project thread with pictures:
http://www.clubpolo.co.uk/forum/index.php?showtopic=289787
