Mk 3 Polo Coupe Project Advice;
Hi I'm about to start doing some body work on my MK3 polo coupe (replacing door and wing, knocking out dents, and some other bits and pieces), and need some advice. Complete novice when it comes to work on cars but learning as I go along, so I have some questions. =)
I've just purchased some clear front indys and side lights and I'm wondering if the car would be road legal if they have clear bulbs in them, or do I need to go out and purchase some amber ones?
The clips for the front and rear bumpers on the car have broken and I've been told you can buy new clips to hold them on properly but don't know where to find them?.. (bumpers still secure but not held on properly).
Can you paint the cam cover in the engine with ordinary black spray paint, or is there something specific I'd need (don't want the paint smoking while I'm half way down the motor way!..) and same for disk air filter?
How do you remove the rear "Polo coupe badges" from the boot as I need to spray some chrome paint on them as some T-cut got on them a year or so ago and they've lost their colour..?
Also how do you attach the plastic wheel arches to the car? Picked some up the other day but not sure what size rivets or where to start.
Will likely come across some other things but will post up again if need be.
Any advice would be hugely appreciated!
Edited by Nick_593
  • Views 826
I've just purchased some clear front indys and side lights and I'm wondering if the car would be road legal if they have clear bulbs in them, or do I need to go out and purchase some amber ones? yes
The clips for the front and rear bumpers on the car have broken and I've been told you can buy new clips to hold them on properly but don't know where to find them?.. (bumpers still secure but not held on properly). Could you plastic weld them?
Can you paint the cam cover in the engine with ordinary black spray paint, or is there something specific I'd need (don't want the paint smoking while I'm half way down the motor way!..) and same for disk air filter? use normal spray paint it'll be fine on these two
How do you remove the rear "Polo coupe badges" from the boot as I need to spray some chrome paint on them as some T-cut got on them a year or so ago and they've lost their colour..? the polo badge should just be stuck into two little holes in the boot and pulls off easily, the coupe badge will be stuck will double sided sticky foam, scrape off with care
Also how do you attach the plastic wheel arches to the car? Picked some up the other day but not sure what size rivets or where to start. Rivets are good , but have alook at a genuine Gt or G40 and see how they are held on
Coupe badge - use some dental floss and a heat gun/hair dryer, then something to remove the tacky residue like bug and tar remover, then polish. You can get automotive grade double sided tape on eBay
