Mk2 Saloon Brake Pipes
Changing the brake pipes on my mk2 saloon, how many brake pipe ends do I need to get?
  • Views 713
Think it through and get under the car and count. It depends on the year as some had 3 outlets on the master cylinder whilst others had 4.
If you can't be arsed to work this out, your not going to enjoy actually bending up the pipes
someone else is doing it for me I just need to get the pipes and the ends
10 ends on a mk3 but the mk3 has a splitter on it, 14 with the rear axel bits.
Going on the 89 mk2 i have here (4 ports MC), its 8, unless your also replacing the tiny bits on the rear axle which brings it up to 12.
cant think of any I've left out.
But on the mk2 I've replaced the fronts with braided hose from the MC to the calliper.
And my mk3 will have braided from the MC to the rear drums (soon to be callipers)
