Lifting The Car? Ingenious Methods Wanted?
Ok,
so I'm starting a new gt project, and basically gonna strip the entire thing to its shell and start over, i want to work on the underside of the car and epoxy mastic it and then some stone chip paint most likely.
But my question is, without the use of a fancy car lift or anything, how can i go about getting the shell high enough to work comfortably? or has anyone tried rolling the car onto its side? if so how? just wondering what ingenious methods people have used?
Cheers guys
  • Replies 13
  • Views 1.7k
Have u ever heard of a jack and axle stands ahaha
Ever thought of looking st the cars at the show you're st Eric? :lol:
You csn buy a jig and put it together for a few hundred
Ahaaha i have! Lol
Not exactly safe ddo. :lol:
TBH id go down the jig route, means you can turn the car at all angles and as most have wheels you can wheel it outside for some in the sun (hahaha) work.
Funnily enough I had thought o that, but was looking for more work space than a couple of feet, :)
Looked at jigs but bit to much money
Could get 4 drive-on ramps, drive the front up on to them and then use a high lift jack and shove them under the back.
Yer could be enough, I want to know how some people get the shell in it's side, seen pictures but don't know how it's supported,
I have had a mk1 escort on its side in my garage to work on. Thick upholstery foam on the floor and the wall. And a huge plastic sheet to make getting rid of all the shite easy.
4 of us just tipped it over.
I'm making myself a car spit if you have £100 and a welder buy two engine stands make a bit to mount them to the bumper mounts front and rear (steel box section) and there you have it
thats how I'm doing mine you have to do them off set to give you clearance so it will only spin one way if you get me
Cheers, two good options there might go with the tipping it tho, can get some old mattresses to protect it,
get a mattress and tip it onto that. tarp on the floor so pulling the shit out is easier :-)
be careful when putting the car on its side as you may twist the shell, also if you go down the route of a spit then make sure you brace the car before putting it on so you dont end up twisting it this way either
tbf half the ''scene'' cars are probably twisted to fuck anyway.... coilovers are way too stiff :lol: Hence me wanting a substantial cage.
