Mk 2 Rear Sill Rust
Hi guys
Basically where the sill meets the rear arch there was a bit of rust, i actually managed the pull the lip of the arch at the bottom off, i when cleaned the area up best i could and primered it then just blackjack hammerite paint.
The rust is purely on the on the edge on the corner, i presume this is a common spot?
What I'm getting at is this some thing the mot man will fail it on ?
  • Views 946
if there is a hole, sharp edges or is structuraly unsafe then it will fail, try get it sorted correctly, i.e welded up. rust weakens the structural integraty of your car so dont do any bodges as its your life and your passengers to think about.
some may say this is an ott reply but having been in the body trade for so long and seeing some of the wrecks that i have seen that have been bodged up then you would understand my reply
both mine had a little rust there. on the passenger side. must be a common thing from leaves/mud collecting there. tis not in a spot which will affect much. your not gonna die if its only a small amount.
Edited by erixtar1992
Very common it seems. It might be worth getting it welded up as my car failed it's last MOT on this.
Cheers for the replys guys
My mot is up in a few months so i plan to sort it before then, or at least speak to the mot man before hand and see what he thinks.
erixtar:
Dont spose u have any pics of the rust on urs?
Oh and was it ever mentioned on mots?
Mattloaf:
Yours is a fair bit worse than mine, the only completly rotten part is the lower arch lip, the rest is rusty but atm still solid, i suppose its how it starts.
So i have a rough idea what price did u pay to have it sorted? Any pics after the repair?
Just so i have a rough idea
Cheers again guys.
