Mk2f Cigarette Lighter
Hi just after some help, i have a polo coupe genesis and it has no cigarette lighter, is it something that i can fit in easily enough so that i can plug my satnav or phone charger into. would the wiring already be there or would i have to wire one in myself.
  • Views 1k
You'll have to add the wiring for some bizzarre reason. If you can get to a scrap yard and grab one , great. Most Golfs etc mid nineties have the same socket. Simple job then to remove the surround, chop the front, run a fused live to the battery (use the rear wiper water hose hole in the bulkhead) and find yourself a good earth nearby. Fuse should be rated to the wire size and have the fuse as close to the battery as you can. There are other places to take the live from, but this way you are guaranteed to only loose this fuse if it blows, still be able to start the car etc.
Be aware though whatever you leave plugged in will drain the battery when the engines off -'but this is also useful when charging phones etc.
Ps centre pin on the socket is +, outer shell -/earth if you didn't already know
got a spare lying around somewhere if your interested.
on my mk2 its connected straight to the battery along with the sterio ect as standard. haven't had a problem with mine draining the batery, it
It will only drain the battery if you leave something plugged in while the engine is off.
