Looking To Buy A 9n
Okay so i currently drive a grande punto and I'm loving the cleaned/euro/stanced scene.
but I'm thinking of downgrading slightly to a 9N as it would leave me with the money to make it just how i wanted.
but i need some things clearing up.
1: How does 16x9J look on the rear? give me some pictures people!
2: how does the 1.2 drive?
3: can i get a Double DIN headunit in there?
in my head my plans are:
1.2 9N in black or grey.
Polished and Gold BBS RS - 16x8 front 16x9 rear.
Coilovers.
MOMO steering wheel.
New interior.
Simple ICE install.
what do people think to that?
  • Views 637
9j on the rear looks wide :) i had a set of 8 1/2 on the rear and kept getting pulled so unless you roll the arches they may be to wide and yes you can get a doubled in there :) will post a pic up of the rear if mine in a bit mate
Will deffo need arches seeing too
1.2 i would imagne would be a bit slow , i drive a 1.9tdi which is 100bhp stock with alot more tourqe nothing amazing so i would think a 1.2 9n is a good town run about?
doubble din slots in with an adaptor i belive , i have a spare one if your local fiver its yours - i brought wrong thing i needed a cubby hole for single din
the 1.2's have been known for unreliability with the most common being the timing chain shitting itself. personally I would aim for a 1.4 at least as it would be more usable and easier to live with as you will find overtaking easier, joining motorways easier, less revving its tits off on the M-way etc.
avoid the 1.2s at all cost, unless it has had the revised timing chain tensioner fitted. be wary of the different bhp models too, there was one 1.2 used early on that only had 50 odd bhp. i would go for either tdi engined cars. the 1.4 is nippy and great on fuel, the 1.9 has a bit more grunt and is still good on fuel and has better tuning options. can't comment on the 1.4 petrol as I've not driven one. make sure the air con works if fitted. mine does some right funky stuff which renders it pretty useless, tis a pig to fix hence why I've not bothered to!
