Swapping Windscreens Mk2f
Could I do it in my garage or do I need gavin from auto glass?
If I can do it, tips/hints/tricks appreciated.
Searched the forum for this, if I failed to find it, point it out & I'll dispose of this.. If I can.
  • Replies 15
  • Views 1.5k
Yeah, it's DIYable. Just off to work so I'll post more later.
Cheers buddy!
did one in the snow in about three hours. only because it was snowing. shouldn't take long at all.
get old glass out, preferably in as few pieces as possible.
get new screen and put seal round it in the in the channel (in the seal) that will be where the the screen will attach insert some thin (maybe 3mm) rope (I used an old electrical cable)push the screen into position and get someone to apply light pressure to the edges as you pull the rope out from inside the car. I am very tired so please leave some time for someone to correct me.
Cheers dude, as long as there's no adhesive it should be piss easy..
But how do I get the windscreen out? It's not broken just has a major chip.. & I'd prefer not to smash it.
sit in drivers seat and push with your feet
shuld pop out
my screen was laminated so even though it broke it stayed largely intact.
You can work the seal on the inside a bit at a time, all along the top and halfway down the pillars, then pull it away from the outside.
It's tedious though, better to push with feet like Eric says - but this will crack the hell out of it.
mine started to crack with the pressure of my thumb pressing against it.
Use a screw driver to push the seal back down under the metal so it stays and then push out and then just reverse to get back in. Shouldn't take more than 30mins
Edited by bikerboywill
So I carefully pushed the seal out under the good windscreen, all along the top, down the pillars, came out, no probs!
The bad windscreen I put my feet on & quickly jolted out, didn't crack, I was surprised.
Getting it back in by myself is proving tricky though! Need my brother or dad home from work!
Been at it a few hours, tried string in the seal, wire in the seal, they both snapped, sticking it back in with the flat head, ain't happening, unless i take the dash out! Really getting ratty with this, I think I'll be getting auto glass out :/ shouldnt be much to install a windscreen.. Unless anyone on here wants to do it for a fee?
Get some very soapy water all around the seal to lube it up, use one chord of thick cable (like 8mm earth cable) pulling that through.
Oh, my brother decided it would be fun to get on the car & push the seal in with his knee, thus smashing my fresh screen, dickhead.
Put the old one back in with doubled up rope. & the original seal after banging it back it place with the palm of my hand & using water & washing up liquid.
Chip in the screen ftw.
The end. :x
At least you've had practice with lube and rope and such
Not the first time, but hey, they'll never prove it.
