Changing The Gearknob On A 2008 9n3
Ok so I have a VW Chrome gear knob and I'm wanting to swap it for the one that is on just now. HOWEVER. I don't have the slightest clue how to change it.
And I don't want to just rag the current gear knob off with sheer force incase I break it.
  • Views 912
Yes, pulling on it will break something.
To get it off you have to pull up on the gator to reveal the metal gear stick and mechanism underneath, Pull the gator all the way up and you will see a metal clip ring, this is holding it on and has been pinched to lock it in place. Simply put a screwdriver into the gap and bend it open you can then take the gear knob off.
Also iirc the gator cannot be separated from the knob so I think the replacement will have to have the gator part as well, but I could be wrong.
HTH
