6n2 Window Issue
Hi guys having an issue with my 6n2. The window goes down perfectly but going up it goes very slowly to about quarter of the way and i have to push it using the switch too the get it bacl up. Any folk got any ideas on how to fix it?
  • Replies 11
  • Views 1.2k
sounds like its popped of the regulator on one side,makes it go up at an angle
whip off the door card ect and you will find the glass sitting on a metal strip,this strip clips onto the regulator with two lugs.
you will see which side off the glass needs popping back in
its most likely the lug nearer the door latch/rear of car
cheers I'll take a look just gotta try and take it all off without damaging anything. I'll keep you posted on progress once I've had a gander on sunday.
As above, but also worth checking that the switch isn't corroded and guving a weak signal. So once the door is offseesp round the connections ie drivers on passengers etc and then try, if it is cured then get the switch to a clean area (lots of small bits inside) and using a thin flat head driver or Stanley knife etc gently open up the back of the switch(wire side) and pull apart you should see four small triangle metal plates, if these have corrosion on them then clean them with emery paper etc and the same with the little silver dots on the board but go easy as they will come off.
IMO its deffinatly worth trying to fix these as they are a small fortune to replace.
Also when looking at the regulators it wont hurt to add a bit of grease to the mechanisms and re seat the window by undoing the 10mm nuts and lifting the window out slightly then pushing back down and making sure they sit snugly before tightening them, most times you will be amazed at how far they have moved.
HTH
thanks for the reply dixy, I have just had the card off and had a gander and the clips are still in place and it doesn't seem like there is any obstruction I think the motor is dying. opinions?
It's not very likely.
Try some wd40 or silicone lube etc down the side channels, if that doesn't cure it then you could also check the wires in the rubber gator between the door and the a pilar, this is a very common failing point as the wires break under the stress of movement. Just pull back the rubber part from the a polar side and have a look, I'm guessing that the big brown wire is damaged.
will hopefully get WD on it today and hope that'll work. thanks again Dixy
lubed them up a good un but still no luck. however upon looking into the door boot i see the live wire has a split in the plastic casing, the cable seems good though.
What do you mean by the plastic casing?
I had more than one do this on my 6n, was the cable not winding up properly and in the end the best solution was a replacement regulator, they're flimsy pieces of shit
Brown covering on the live wire is split, but the copper seems intact, could be shorting no?
Also 'arris the regulator is fine.
If the outer sheething is split the the wire is broken inside. Cut it off (the Brocken part) and solder on a new section.
Also once your done then what I have found is if you cover all the wires with a grease (not copper) then this will greatly reduce the friction between the wires and then they are less likely to break again.
